Forums >> Revit Building >> Technical Support >> .txt Conversion to .pdf
Tue, Apr 11, 2006 at 2:12:10 AM | .txt Conversion to .pdf
whoopsyvroom
May be a silly question but I have been trying to export Schedules and convert them into pdf files.without success. Without purchasing a specific program what are the steps .
Tue, Apr 11, 2006 at 4:05:26 AM | RE: .txt Conversion to .pdf
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
1. Place the schedule on a sheet and print from revit OR 2. Open the schedule and go to file-->export-->Schedule-->as tab deliminate text file. Then open them in Excel, format and print from there... HTH.
Tue, Apr 11, 2006 at 5:14:10 AM | RE: .txt Conversion to .pdf
whoopsyvroom
Thank You Mr spot. Works well. Wish there was something I could do to help you. Just ask. Have a safe and good Easter
Wed, Feb 8, 2012 at 3:43:28 AM | .txt Conversion to .pdf
csteve274
3 Stars: 2 Votes
Hi,You can download and use the better pdf converter tool from here. Hope this might help you.
http://www.downloadsversion.com/search/pdf-converter/1
Thanks
Edited on: Wed, Feb 8, 2012 at 3:45:45 AM
PDF conversion
Sun, May 3, 2009 at 7:09:59 PM
How to set custom unit conversion value
Thu, Jul 17, 2014 at 5:27:32 AM
RST 2010 keyboard shortcuts - TXT file vs Options list
Thu, Feb 11, 2010 at 8:33:17 AM
txt file with families
Wed, Jun 13, 2018 at 4:10:35 AM
IMPORTING / LINKING; XLS / TXT
Fri, Jun 23, 2006 at 3:08:39 PM
Page generation time: 0.4021
