Forums >> General Discussion >> Revit Project Management >> Revit FBX causes 3DS Max to crash
Tue, Jun 7, 2016 at 4:24:18 PM | Revit FBX causes 3DS Max to crash
thinkpositive
5 Stars: 7 Votes
Okay I tried doing this with Revit and Max 2014 and now with Revit and Max 2017. Whenever I try to import an FBX in Max which was exported from Revit for the purposes of rendering, my Max crases before the model even loads up. It works fine if I export as dwg from Revit and then link that dwg into Max, but FBX does not at all seems to be working for me. What could cause this? My revit file has a bunch of links and nested linked revit files.
Wed, Aug 10, 2016 at 6:02:27 PM | Revit FBX causes 3DS Max to crash
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
One way to make this workflow efficient (and error free) is ensure that you isolate sections of your model in separate 3D views, and export them in those chunks to FBX. From there, when importing into max, you have options for grouping elements by material which can help futher consolidate elements into easily selectable chunks for rendering. You could be simply overloading max with your export so I would try these steps to see if you have any better luck. I'm thinking you will ;-) Cheers.
Exporting FBX file from Revit to 3Ds Max
Wed, Sep 30, 2020 at 1:36:49 PM
Revit to 3DS Max and creating FBX files
Fri, Apr 26, 2024 at 4:30:41 AM
3ds Max Design 2009??? importing from Revit 2009???
Thu, Feb 26, 2009 at 8:01:56 PM
problems with Revit 2013 in 3ds Max!
Fri, Dec 14, 2012 at 4:25:44 PM
13
Revit 10 Model to FBX to 3Ds Studio Max Design lighting problem
Sat, May 1, 2010 at 12:55:25 PM
Page generation time: 1.6199
