Forums >> Revit Structure >> Technical Support >> Curved height level in revit architecture 2014
Tue, Jun 7, 2016 at 5:18:47 AM | Curved height level in revit architecture 2014
deeja89
dear all,
i got a problem, im working on a building with a cruved roof, and now i need to place a dosen
lightstreets on this curved roofprofile,
but the alligntment is impossible since i cant make a curved height lvl, so i cant connect all the lightstreets correctly to the roof,
how do i fix this? or what is the best way in working with this.
kind regard sander,
Tue, Jun 7, 2016 at 7:03:54 AM | Curved height level in revit architecture 2014
Sorry - I don't know what a "lightstreet" is.  If it is just a light source, does it rotate with this curved surface or always cast light in the same direction?  Families have an "always vertical" switch than can be turned off and you can build families that can be rotated off vertical.   You can also build face based families.
YOUR OPINION ON REVIT ARCHITECTURE 2014 VERY URGENT
Tue, Apr 30, 2013 at 11:09:29 PM
Create in-fill walls under spiral stairs - Revit Architecture 2013 specific
Thu, Jul 7, 2016 at 10:50:48 AM
Greyed out level and height options on family / group
Wed, Jan 6, 2016 at 1:06:24 PM
Topo Height vs Level Heights
Fri, May 13, 2005 at 3:25:34 PM
Curved Roof Problems
Mon, Apr 7, 2014 at 9:00:04 AM
Page generation time: 6.4540
