22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> grouping nightmare
31 Posts No Rating |
Hello all,
I have grouped a unit type in a condoplex.
I want to swap out the group with a slightly modified group, which I had to modify, because revit told me to.
when I try to swap unitA for the updated unitB it disappears..
has this happened to anyone else?
any thoughts
callum
Delete the unit A group and then use place group to insert unit B. Swapping the group may not be locating properly and ending up in some strange location...
Just a thought.
1 Posts No Rating |
I have been testing using groups in Revit. A lot of the matrix operations used to flip, rotate, etc seem to be fairly dodgy.
Version 7 is supposed to address a lot of these issues.
We do a lot of multistorey work and I would quite frankly steer clear of using groups. I would certainly not put any walls into a group. It just does not work with any real certainty at present.
Thats interesting i find walls one of the few things were groups are certain. Remember its always a good idea to edit the wall joins of walls within a group that are to join with walls not within the group and set them to "disallow join"...
12 Posts No Rating |
You might want to check the origin of both groups?
Grouping Floors |
Mon, Aug 22, 2005 at 3:47:49 PM
Graphical Column Schedule - Not Grouping all similar instances |
Wed, Nov 5, 2008 at 11:11:18 AM
Grouping issue |
Mon, Dec 19, 2016 at 12:12:45 PM
Grouping Line-based Families |
Mon, Oct 30, 2006 at 12:00:45 PM
Moving whole building |
Fri, Mar 20, 2009 at 7:51:37 AM
