Forums >> Community >> Newbies >> surface hatch in views
Fri, May 27, 2016 at 9:59:13 AM | surface hatch in views
kdrobertsarch
Hi, i am having trouble figuring out how to make surface hatches show up at angles in camera views.  I know it has to be a distance/angle thing but i've seen other peoples renderings where this does not occour.
i've attached a view where the rock base only displays for certain surfaces.
thanks,
ken
Sat, May 28, 2016 at 1:42:44 AM | surface hatch in views
hugh
3.5 Stars: 4 Votes
Could be the hatch contains so many short segments that beyond a certain distance Revit won't show them and substitutes solid grey.
A test would be to run the same view with a different. very simple hatch and if that hatches all surfaces properly you could either scale up the stone hatch (if Revit allows) until it displays properly. If that turns out to be too large you could substitute with another simpler, larger stone hatch.
You can rescale hatches indefinitely within your project without reloading from their parent .PAT file using our free HatchKit Add-In for Revit.
Hugh Adamson
www.hatchkit.com.au
Surface Hatch Pattern on Topography/Subregions
Fri, Oct 24, 2008 at 11:30:56 AM
Using Region (hatch) in Multiple Views
Wed, Mar 14, 2012 at 8:41:05 AM
Removing surface hatch - crash
Tue, Sep 1, 2009 at 10:48:45 AM
surface pattern hatch override
Tue, Apr 4, 2006 at 12:28:50 PM
2D Stone Hatch for Drafting Views
Wed, Mar 20, 2013 at 9:47:40 AM
Page generation time: 0.4347
