19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> location line of wood sheathing
I'm working on a project this is being build with panelized wood construction and so they are placed with OSB sheating inline with face of foundation. Dimensioning is done from face of sheathing and not face of stud. Is there a way to locate exterior stud walls by face of substrate (OSB) and not core or finish. thanks....
The only location options are what you see. I usually relocate these walls from section views where I also join the floor with the wall to cut the wall out.
From a working view, you could do a 2D line, with offset thicknee to the exterior wall face, using the pick line method tabbing to select the complete exterior then use the wall exterior.
recommended way of modeling wood-framed roof? |
Mon, Nov 5, 2012 at 3:34:01 PM
Displaying 2X6 wood frame walls in floor plan |
Tue, Feb 6, 2007 at 10:00:52 AM
Wood Framing - add top & bottom plates to wall family? |
Mon, Jan 19, 2009 at 12:22:00 AM
Vertical line in exterior rendering |
Thu, Feb 23, 2006 at 3:29:25 PM
Wood floor way too shiny. |
Tue, Dec 14, 2010 at 7:32:39 AM
