Forums >> Revit Building >> Technical Support >> Can't create monolithic stairs (Revit 2013, beginner)
Wed, May 25, 2016 at 7:55:09 AM | Can't create monolithic stairs (Revit 2013, beginner)
ontaneas
Hi there everybody.I am quiet new to Revit. There is probably something I don't understand exactly.I try to create a monolithic stairs and get the error: "can't create monolithic stairs".The result is at the attached image.
I'd appreciate any hints. Thank you much in advance. Best, ontaneas...
Wed, May 25, 2016 at 8:27:18 AM | Can't create monolithic stairs (Revit 2013, beginner)
That's not a monolithic stair.  If you can't finish the stair, where did you get the image?
Your problem is your stair sketch.  Winder stairs are hard to do, especially for beginners.
Wed, May 25, 2016 at 10:39:49 AM | Can't create monolithic stairs (Revit 2013, beginner)
ontaneas
Hi there.
At the create process the option is set to 'monolithic stairs'. Revit alerts an error at the end: 'Cant't create monolithic stairs'. Despite the error, the stair is created as presented at the attached image...
Edited on: Wed, May 25, 2016 at 10:49:33 AM
Wed, May 25, 2016 at 10:59:45 AM | Can't create monolithic stairs (Revit 2013, beginner)
I think someone has changed the defaults here.  Look at my image and check your 'monolithic' properties.  Under construction, is the monolithic stais checked?  I doubt that it is looking at your images.   I don't know if that is what is causing some of your problem.  Monolithic stairs are really like cast solid concrete stairs and a winder stair will look more like my image.
Either way, the problem is how you sketched your stairs.   As I said, winders are hard to do and you need more tutorial work.
Fri, May 27, 2016 at 11:21:56 AM | Can't create monolithic stairs (Revit 2013, beginner)
20clarsen1
wow WWHub is so smart
monolithic stairs
Thu, Mar 15, 2012 at 11:34:58 PM
monolithic stairs
Sun, May 16, 2010 at 6:33:12 AM
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Monolithic stair PROBLEM
Sat, Feb 9, 2013 at 8:14:32 AM
CAN'T MAKE MONOLITHIC STAIR
Fri, Feb 5, 2016 at 10:16:18 AM
13
Page generation time: 1.8246
