13 Users Online (12 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Issue with annotation nested with generic model family
Wed, May 25, 2016 at 7:42:13 AM | Issue with annotation nested with generic model family
teejayrobinson
I have a family that is wall based with a generic annotation nested in with it to display a symbol in plan in the project. The problem I'm having is that when the model sits above the cut plane, the annotation that's loaded into the family also disappears. If the model is being cut by or sits below the cut plane, everything works fine. My question is basically if there is a way to have the annotation show up even if the model that the annotation is loaded into is sitting above the cut plane. I've attached an example of the family in question so you can see what I'm working with. I appreciate any help that is provided.
Wed, May 25, 2016 at 7:49:25 AM | Issue with annotation nested with generic model family
If the family is non-cuttable, you can place a vertical invisible line in the family that will intersect your view cut plane, then the entire family will show.
Wed, May 25, 2016 at 7:59:47 AM | Issue with annotation nested with generic model family
teejayrobinson
Is the only way to make a family not cuttable is to change its category? Thanks for the response
Wed, May 25, 2016 at 8:23:00 AM | Issue with annotation nested with generic model family
Yes ... but we are talking about your wall based family, not the nested family.  Is that also generic?
Wed, May 25, 2016 at 8:27:09 AM | Issue with annotation nested with generic model family
teejayrobinson
It is generic but can be changed if necessary to get the family to function the way I want.
Wed, May 25, 2016 at 9:46:10 AM | Issue with annotation nested with generic model family
teejayrobinson
Got it to work, Thanks for you help!
Text issues with generic annotation family nested into detail component.
Mon, May 19, 2014 at 11:27:43 AM
Annotations nested inside a wall hosted equip family: Cant see the annotation
Wed, Aug 20, 2008 at 6:37:31 PM
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:45 AM
Generic Annotation with Family Category based parameter
Mon, Sep 16, 2013 at 7:18:15 PM
Draggable Line in an Annotation family?
Thu, Jul 5, 2012 at 1:30:26 PM
Page generation time: 1.1537
