Forums >> Revit Building >> Technical Support >> So so so urgent I need a help
Mon, May 23, 2016 at 7:40:32 PM | So so so urgent I need a help
leahdudu
I am using Revit 2015 and am having trouble exporting to DWG. It gets to 54% and then reverts to the Revit screen. Then when I try to zoom in or out it freezes and a box pops up that says a fatal error has occured and then asks me if I want to save a recovery file. It creates the DWG file but there is nothing in it. I have searched numerous threads and cannot find anything similar to my problems. I've tried exporting about 10 times and the same thing happens everytime. I've also tried exporting to DXF but the same thing happens. I would appreciate any help I can get. Thanks.
Tue, May 24, 2016 at 7:38:55 AM | So so so urgent I need a help
We don't have enough information to give much of an answer.  One possibility is computer memory.  Revit builds temp files during this action and if you have not cleaned your system recently, that could be your problem.  CCleaner is free and will clean your temp file area as well as cookies and other junk.   Be aware that you may lose memorized passwords depending on what you clean.
Tue, May 24, 2016 at 10:24:35 AM | So so so urgent I need a help
AmyEAmyW
How large is your model? Do you have a large number of inserted DWGs or linked files in the model? I would suggest auditing it to find if there are any issues with your model and purging unused elements and views to reduce file size.
The above reply regarding your computer's memory could be the issue as well.
The only other explanation I could think of is that the Revit program file (.dll) that manages exporting to DWG is corrupt (but I can't imagine how that would happen).
-Amy
Wed, May 25, 2016 at 2:08:29 AM | So so so urgent I need a help
leahdudu
Thanks WWhub & Amy for your respone iam appreciate it...
Amy my file is almost 500,000 Kb & I do my best to clean it very well
But still have same issue
Wed, May 25, 2016 at 8:51:35 AM | So so so urgent I need a help
You don't say if you cleaned your system.....
I'm not sure if the free version available on this site still does what our copy does but I suggest you try it.
help its urgent
Thu, Dec 19, 2019 at 6:19:26 AM
very urgent- S.O.S!!! applying lights on render
Fri, Feb 10, 2006 at 3:22:49 PM
Accurender file location
Sat, Nov 1, 2008 at 9:19:35 AM
plz ite really urgent i need some help :(
Thu, Mar 15, 2018 at 8:47:07 AM
RENDERING PROBLEM NEED HELP URGENT...
Fri, Dec 4, 2009 at 8:00:12 AM
Page generation time: 0.9148
