Forums >> Revit Building >> Technical Support >> Revit Small Size Network - Three Computers.
Mon, May 16, 2016 at 3:53:04 PM | Revit Small Size Network - Three Computers.
belazaras
I want to configure a Small Revit Network to access and share a central file.
In a three Workstations environment, I plan to make a partition in my HD (E: drive in Workstation #1), share it and remapping as a Z:\... So, I so, the others two computers access to the same drive as a Z: path.
In Workstation #1, it will be the E:\ drive and the Z:\ drive wich it´s the same thing with two names. I will create a central file in Z:\ and and save a local file in C:\Local File\
Wprkstations #2 and #3 open the Z:\ central file an save it´s own C:\Local File .
It is the correct procedure ?
There´s no problem having a shared repository of central files and libraries on a separate partition in the Workstation #1 ?
Thank you all,
Wed, Jun 1, 2016 at 3:00:18 PM | Revit Small Size Network - Three Computers.
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Thats sounds good. Your workstation 1 partition acts like a server and each day each workstation opens that central file and creates a new local file over-writting the previous days file.
revit arch rendering on multiple computers
Mon, Mar 5, 2012 at 2:33:29 PM
Do we need a network license for our Revit in order to do Worksharing?
Fri, Nov 11, 2011 at 2:22:45 PM
Central File Too Big
Mon, May 19, 2008 at 5:01:28 PM
Working over a network & file size
Thu, May 25, 2006 at 11:07:37 AM
Revit 2011 Network Drives Disconecting for Windows Vista
Tue, Sep 21, 2010 at 2:05:39 PM
Page generation time: 2.5940
