Forums >> Revit Building >> Technical Support >> family symbol lines not in proper plane
Tue, May 10, 2016 at 3:13:55 PM | family symbol lines not in proper plane
Warchitect
4 Stars: 5 Votes
So CHeck th pic.
My symbolic lines for my window are way down on the floor plane. Do I need to open the family and rehost these to sit on the sill? I thought these were not model lines, but just lines in plan so you could hide the geometry of the window and have a cleaner graphic for the window operation etc...
Am I picking the wrong lines to draw?
Thanks in advance.
Michael
Tue, May 10, 2016 at 3:30:27 PM | family symbol lines not in proper plane
If you can see them in a model view >>>> then they are model lines!
Select them and pick convert.
Tue, May 10, 2016 at 4:13:48 PM | family symbol lines not in proper plane
Warchitect
4 Stars: 5 Votes
Thanks, seemed like a good simple fix. see pic. convert is greyed out.
Wed, May 11, 2016 at 7:48:08 AM | family symbol lines not in proper plane
How can you draw a 2D line in a 3D view?  You can't!   Pick them in the 3d then switch to 2d plan view then the switch will be available.
Unless of course if this is two mulled, nested window families in which case the lines may be in those families.
Wed, May 11, 2016 at 12:12:51 PM | family symbol lines not in proper plane
Warchitect
4 Stars: 5 Votes
HAHA! that worked. didn't realize that was a thing but of course it makes sense.
Sink Family - Symbol Lines won't flex with Wall Change in Section View
Mon, Mar 9, 2009 at 5:26:15 PM
Proper labels
Tue, Apr 26, 2011 at 7:07:40 AM
2D nested annotation symbol doesn't show when family is sloped in 3D
Tue, Aug 2, 2011 at 2:58:56 PM
2d electrical symbol line wieghts
Wed, Jul 21, 2010 at 1:01:49 PM
RCP componenet symbol visibility
Tue, Feb 5, 2013 at 9:41:26 AM
Page generation time: 3.8237
