Forums >> Revit Building >> Technical Support >> Creating window check reveals
Fri, May 6, 2016 at 8:58:55 AM | Creating window check reveals
Ryvesey
Hi
Im new to Revit, and we are in the process of creating house types for one of our clients.
I am having trouble creating windows with 20mm check reveals.
Can this be done? if so, how?
Any help would be appreciated.
Thanks
Fri, May 6, 2016 at 10:16:00 AM | Creating window check reveals
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Yep in elevation use void form sweep that is locked to follow the reference lines setup that define the opening cutout and locked to the outer face plane of the wall. Then once the sweep path is finished, go to section and define the shape of the sweep 20 x 20mm?, you can lock that to the reference line that is locked to the outer face of the wall, locked to the reference line that defines the opening reveal or head or window (wherever the profile sketch plane is set. For the other two sketch lines put on a dimension of 20mm to them and lock them too.
I hope that helps.
Wall Reveals
Mon, Jul 9, 2007 at 11:55:45 AM
Reveals in flat roof
Mon, Mar 26, 2012 at 7:07:43 AM
Window reveals in thick stone walls
Tue, Nov 9, 2010 at 12:30:00 PM
Creating Window Sills
Tue, Jul 3, 2012 at 1:26:39 PM
Legends for creating window or door schedules
Thu, May 29, 2008 at 11:18:05 AM
Page generation time: 5.0320
