Forums >> Revit Building >> Technical Support >> modelling
Mon, Apr 10, 2006 at 5:11:52 AM | modelling
Luap
Hi fellow revit users wondering if you can help I am setting up a camera in my project to view various angles of a rock wall. In 3D the rock wall looks fine in a camera view the same wall is almost black I have tried using both drafting and modeling patterns for the surface of the wall but no luck.' any help appreciated. thanks luapj
Mon, Apr 10, 2006 at 2:12:42 PM | RE: modelling
pepsiqueen
pepsiqueen Avatar
what if you render the 3d view with a rock material instead of just a shaded view
Mon, Apr 10, 2006 at 3:59:52 PM | RE: modelling
Luap
Hi thanks for the response, I dont have the time for the rendering this is for a quick presentation but would still like to have the rock wall visible in the shaded view as it is in the 3D view we work in metric in australia and I was thinking because the fill patern was created in imperial units that i would somehow have to cahnge the scale when impoting the pattern in, however it will not allow me to change the importing scale either. cheers luap
Mon, Apr 10, 2006 at 5:21:31 PM | RE: modelling
crarchitect
Hi, I have had rock walls go black in shaded mode when they are CURVED in plan. I had a great looking rock pattern working on the other sections, but the one section that was a curved line showed the pattern as solid black. Seems like a bug... Sorry for the bad news. Get to like black. best regards, Chris
Mon, Apr 10, 2006 at 5:31:03 PM | RE: modelling
Luap
thanks chris this is not a curved wall and it only appears black when i have set up a camera view cheers
Mon, Apr 10, 2006 at 6:08:57 PM | RE: modelling
archdan
3.5 Stars: 2 Votes
Have you tried changing the color for the rock material in the material library? It defaults into an average color of the image which is to be used for rendering. I would also try chanigng the color of the surface pattern in the object styles window or object properties. The other option would be to change the scale of the camera so that image is larger and the scale of the pattern is reduced, then shrink to fit when printing. Those are just a few quick ideas hopefully one will work or spur some other ideas.
Mon, Apr 10, 2006 at 8:22:58 PM | RE: modelling
Luap
thanks will give them a go luap
HELP! WHERE IS THE MODELLING TAB LIKE IN RAC2010?
Fri, Oct 23, 2009 at 10:38:24 PM
Modelling Lake&Stream in Revit 2009
Wed, Jul 29, 2009 at 9:04:17 AM
a better 3D modelling environment
Mon, Aug 6, 2012 at 1:10:07 AM
input devices for modelling
Wed, Oct 26, 2005 at 9:26:45 PM
modelling interior nightclub
Tue, Sep 6, 2005 at 3:57:38 PM
Page generation time: 1.2314
