Forums >> Revit Building >> Technical Support >> Graphic Display Options Acting Strange
Thu, May 5, 2016 at 12:45:09 AM | Graphic Display Options Acting Strange
DTHartcher
Hi,
I've recently started a new project and the 3D view seems to be playing up and i cant work out why. The display, no matter what mode it is in (hidden line - realistic), is 'glitchy' or sketchy?Also in all the modes 'show edges' is ticket and every edge was visable through the model, as if the model had transparency turned on. (As seen in capture_02)
The images below show how the diplay looks. Would really appreciate advise.
Thanks a lot,
Dan
Thu, May 5, 2016 at 4:30:08 AM | Graphic Display Options Acting Strange
4 Stars: 205 Votes
It seems like a ghraphic card issue, try to update drivers.
Edited on: Thu, May 5, 2016 at 4:30:34 AM
Graphic Display Options Unavailable
Thu, Sep 4, 2014 at 8:00:15 AM
Graphic display options assemblies
Thu, Nov 21, 2024 at 3:35:02 PM
Graphic overrides (phasing) for 3D views
Wed, Apr 30, 2014 at 2:25:42 PM
Adjusting Graphic Display Options for Single Item?
Fri, Aug 5, 2011 at 5:01:03 PM
walls acting strange
Mon, Apr 19, 2010 at 9:35:05 AM
Page generation time: 0.2298
