Forums >> Revit Structure >> Technical Support >> Editing hights
Tue, May 3, 2016 at 4:38:54 AM | Editing hights
VisualDesignMojo
I have an annying problem which might be basic but i cant figure out. I'm creating a stucture with purlins and trusses but strange happens are starting to create problems. I have attached a picture indicating the problem.
The just of it is certain trusses refuse me to edit there hights. Then, when trying to edite my colmb hight, it does the same. This isnt a commen accurance, only on a select few experience the problem.
I have looked for any locks, puzzel pieces and connected elements.
Please advise
Tue, May 3, 2016 at 6:36:15 AM | Editing hights
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Are the columns hosted incorrectly?
Tue, May 3, 2016 at 6:46:10 AM | Editing hights
VisualDesignMojo
yes they are...
Tue, May 3, 2016 at 6:47:17 AM | Editing hights
VisualDesignMojo
I mean... they are hosted correctly.
Tue, May 3, 2016 at 11:31:44 AM | Editing hights
20clarsen1
have you just tried dragging the arrow in elevation view to make them taller?
Wed, May 4, 2016 at 8:56:53 AM | Editing hights
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Maybe repeat the process, but what works for me sometimes is to CTRL+X and then use the "Paste in same place" button on the ribbon.
Revit does that to me on wall openings and certain other system families.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Mon, May 9, 2016 at 7:52:16 AM | Editing hights
VisualDesignMojo
None of this helped...
I need to be able to solve the problem. Not avoid it, or work around it.
Mon, May 9, 2016 at 8:04:42 AM | Editing hights
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Avoiding it is what happens when you do it right. By doing it right you are working around the wrong way of doing it which is the way you appear to be doing it now.Hosting, dragging arrows, pasting in place are all valid methods to do the columns right which seem to work for everyone else. We are just recommending common reasons for why the column isn't the right length. So chill ya boots man.Can you not copy a column that has the correct height and paste it - from your image there appears to be a number of them at the correct hgith already.
Stairs with different riser hights.
Tue, Dec 19, 2017 at 6:46:14 AM
level hights displayed
Fri, Dec 23, 2005 at 1:07:14 PM
rough-in hights in schedules
Tue, Mar 24, 2015 at 8:25:56 AM
Roof
Thu, May 22, 2008 at 7:11:42 AM
Editing Keynotes
Tue, Sep 14, 2010 at 9:47:45 AM
Page generation time: 0.4143
