Forums >> Revit Building >> Technical Support >> Revit 2016/2015 revit save to new file unable to copy elements from file
Mon, May 2, 2016 at 12:50:17 PM | Revit 2016/2015 revit save to new file unable to copy elements from file
HermanMunster
I have googled this multiple times and every post is about copy pasting elements or exporting from AutoCAD on inserting views into an existing project. I have had no issue before right click save to new file and the drafting view is exported from a project and saved as a new file
A team member is trying to save views to new file from their demo project. It goes through the motions and then states unable to copy elements from file.
Probably an ambiguous comment but I could not find workarounds to solve this. Here is an autodesk response but it didn't address error to create a new file from a drafting view.
https://forums.autodesk.com/autodesk/attachments/autodesk/133/35138/1/Insert%20from%20file.mht
Cheers
Thu, May 5, 2016 at 2:20:37 PM | Revit 2016/2015 revit save to new file unable to copy elements from file
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
http://revitcat.blogspot.co.uk/2015/03/copying-views-between-revit-projects.html
REVIT 2015 DELETE FAMILIES FROM FILE BEFORE OPENING IT - UNRECOVERABLE ERROR
Thu, May 12, 2016 at 7:57:15 AM
Error when inserting drafting view from file "Unable to copy elements from file"
Thu, Apr 1, 2010 at 5:06:39 PM
Urgent! Help... unable to save
Thu, Dec 20, 2012 at 8:05:42 AM
The file is already open for editing by another user. You will unable to save an
Sun, Apr 29, 2012 at 9:17:33 AM
'unable to copy elements from file' error in inserting a saved view
Wed, Jul 25, 2012 at 10:16:55 AM
Page generation time: 1.7285
