Forums >> Revit Building >> Technical Support >> Revit 2015 how can I create or edit a poche?
Fri, Apr 29, 2016 at 11:30:49 AM | Revit 2015 how can I create or edit a poche?
kcy22
I would like to create a new poche or edit the current one. I have found the thread before, but I can't find it anymore. Based on the thread, I had to find a text document and change or add the coordinates in series in order to show the continuation of lines (and thicknesses too?).
Based on my bad memory, the file was located somewhere around  C:>ProgramFiles>Autodesk>Revit 2015>.......
If you know the answer to my questions, please reply. If you have more in depth infomation, I would love to take a look at it.
Thank you!!
-Kyung
Fri, Apr 29, 2016 at 3:23:32 PM | Revit 2015 how can I create or edit a poche?
poche's are called Pattern Files or Hatch Files.  They are simple, non formatted text (txt) files but with the txt extension changed to PAT.
The initial file loaded with Revit is one file that contains all of the initial patterns.  You do not want to edit this file but you can copy it to remove portions that you may want to edit to create new files.
To understand these files, look at the PDF file I posted in this thread (about 7 posts down):
http://www.revitcity.com/forums.php?action=viewthread&thread_id=36357
Fri, Apr 29, 2016 at 8:29:49 PM | Revit 2015 how can I create or edit a poche?
hugh
3.5 Stars: 4 Votes
Look for and study file revit.pat
Unfortunately hatch pattern definitions specify only line position and length and do not specify line thicknesses, linestyle or color.
hth,
Hugh Adamson
www.hatchkit.com.au
revit 2016 poche
Wed, Sep 23, 2015 at 2:50:33 PM
Wall Poche and Phasing....
Wed, May 31, 2017 at 8:40:33 AM
Poche Not Printing?
Tue, Sep 10, 2013 at 10:11:37 AM
Walls, Floors and Roofs to show hatch pattern AND color poche?
Sun, Apr 29, 2012 at 12:24:19 PM
Creating two surfaces for NGL & Finished, Poche Display
Tue, Mar 27, 2007 at 5:58:27 PM
Page generation time: 2.3179
