11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Cutting irregular openings in curved walls
24 Posts No Rating |
I followed Mr Spot's tutorial on cutting out profile of stairs onta a curved wall, but ran into a snag. The void cut the wasll jsut fine, but when I want to finish the Mass, I got a message saying that the Void was not cutting anything. So I couldn't save the Mass... if I drew in a new mass and cut it with a void, it worked, but of course I lose the wall construction, sweeps, etc. Anyone run into this problem?
Did you use the cut geometry tool to tell the void to cut the wall before finishing the mass?
And are you creating the in-place void as a wall category family? as this is the correct method.
Post edited on 2006-04-09 18:44:13
That was it! I was creating a new mass, not a wall. Thanks. btw, I used a simple extrusion instead of all the reference lines, and it worked as well.
Curved wall openings |
Fri, Oct 15, 2010 at 12:42:11 AM
Openings on a curved roof |
Sat, Jul 25, 2009 at 2:35:49 AM
Curved Walls with Openings |
Tue, Feb 26, 2013 at 12:35:38 PM
Problems with Curved Walls and Masses |
Thu, Mar 20, 2008 at 12:09:01 PM
Irregular (on plan) shaped walls |
Thu, Nov 23, 2006 at 3:28:47 AM
