Forums >> Revit Building >> Technical Support >> Trouble with .pat files
Thu, Apr 28, 2016 at 1:07:33 PM | Trouble with .pat files
DutchAwj
So I'm trying to make a really simple fill pattern that I can use to represent form lines in concrete. We want to use a spacing pattern of 6" and 4" and we want the lines to be vertical. If that maade sense, pretty much we are going to stagger 2x6's and 2x4's side by side to give our concrete a nice vertical pattern.
Where the trouble lies is making the .pat file to do this and seem to be running into nothing but problems here, i have spent that last 3 hours watching videos and reading forms as to what i need to do and what i might be doing wrong and at this point i hit a dead end and got really frustrated.
So i built multiple .pat file and a lot of the time for one reason or another that i cannnont explain its coming in as [No "drafting" type patterns found] although i have a [;%TYPE=DRAFTING] in my file, and when i i do get something to finally come in it shows up as blank.
heres whats in my file...
this one comes in blank
*CUSTOM 4 6,  4 6 CONCRETE
;%TYPE=DRAFTING
90,             0,             0,             0,             10
90,            6,             0,             0,             10
this one ays no "drafting type found
;%TYPE=DRAFTING
90,             0,             0,             10,             0
90,            6,             0,             10,             0
Please help i dont understand what im doing wrong.
Thu, Apr 28, 2016 at 1:29:44 PM | Trouble with .pat files
marmiketin1
4.5 Stars: 10 Votes
Try just this
90,             0,             0,             10,             0
90,            6,             0,             10,             0
Thu, Apr 28, 2016 at 1:33:14 PM | Trouble with .pat files
marmiketin1
4.5 Stars: 10 Votes
Its usually better to make it as a model pattern so you might want to do this
*CUSTOM 4 6,
;%TYPE=MODEL
90,             0,             0,             10,             0
90,            6,             0,             10,             0
Edited on: Thu, Apr 28, 2016 at 1:34:02 PM
Edited on: Thu, Apr 28, 2016 at 1:34:47 PM
Thu, Apr 28, 2016 at 1:34:02 PM | Trouble with .pat files
DutchAwj
Thanks for such a quick reply, unfortunally it still saying [No "Drafting pattern found] Same with Model
Thu, Apr 28, 2016 at 1:36:42 PM | Trouble with .pat files
marmiketin1
4.5 Stars: 10 Votes
sorry forgot to remove the second 4 6 CUSTOM, I edited my last post showing how it should be
Thu, Apr 28, 2016 at 1:40:54 PM | Trouble with .pat files
DutchAwj
Unfourtunatly I am still getting the No "model" pattern found error message
Thu, Apr 28, 2016 at 1:43:40 PM | Trouble with .pat files
The problem has nothing to do with model or drafting pattern, it is in your numbers.   I will suggest that you want this to be a model, not a drafting pattern.
The attached is a good explanation for patterns.   I did not create this and I do not know who posted it on-line.
Thu, Apr 28, 2016 at 1:45:14 PM | Trouble with .pat files
THIS MUST BE A SIMPLE TXT FILE SAVED WITH .PAT EXTENSION - NO FORMATTING.
Thu, Apr 28, 2016 at 1:47:51 PM | Trouble with .pat files
marmiketin1
4.5 Stars: 10 Votes
just tested it and this one works, the offset was was wrong way round
*Concrete Form,
;%TYPE=MODEL
90,    0,0,     0,10
90,    6,0,     0,10
Thu, Apr 28, 2016 at 2:02:25 PM | Trouble with .pat files
DutchAwj
To: WWHub - thanks a lot thats by far the best info for creating .pat files ive seen all morning, super informative and clear  to read and your right about my numbers being wrong.
To: marmiketin1 - Thanks much i tried yours directly and it was still saying that it could not find a model pattern, but once i put the spacing in between the numbers it worked fine
Thank you both very much for being quick and responsive i think my biggest issue was trying to do this as a drafting instead of a model pattern because i had it right in my first go around it just needed to be model instead of drafting
Pat Files
Thu, Jan 22, 2009 at 1:26:47 PM
looking for .pat files [ 1 2 ]
Tue, Dec 1, 2020 at 1:43:31 PM
24
Use Pat Files
Tue, Sep 1, 2009 at 4:18:40 AM
11
Is there a way to preview .pat files / hatch patterns in thumbnails in a folder?
Mon, Jul 6, 2015 at 11:01:26 AM
custom pat files
Fri, Oct 21, 2005 at 3:13:23 PM
Page generation time: 2.5249
