Forums >> General Discussion >> Revit Project Management >> Disallowing All Curtain Wall Joins
Thu, Apr 28, 2016 at 7:57:49 AM | Disallowing All Curtain Wall Joins
pleojera
pleojera Avatar
Hi, i want to place a balcony window unit in a project, as i shared below.
http://www.unyecam.com/lib/images/urunler/6379_cambalkon4.jpg
I decided to make them with CW for easiness (image attached). But they automatically joins with wall, sweeps and other elements which i do not want. Is there any option to automatically disallow all CW type by default? Or what do you suggest as a family do make this units?
Thu, Apr 28, 2016 at 8:56:01 AM | Disallowing All Curtain Wall Joins
When you place your curtain wall, look at the right side of your options bar.... see image below.
Fri, Apr 29, 2016 at 1:57:16 AM | Disallowing All Curtain Wall Joins
pleojera
pleojera Avatar
Thanks WWHub but interesting... I don't have that option (Revit 2015). There is an option in "Type Properties" called "Join Condition" but it only has these options: "Not defined", "Vertical Grid Continues", "Horizontal Grid Continues", "Border and Vertical Grid Continues" and "Border and Horizontal Grid Continues" but none of them worked so far. And one more question for you, Revit still does not support wall (walls, cw's, etc.) length tag, right?
Fri, Apr 29, 2016 at 8:48:30 AM | Disallowing All Curtain Wall Joins
This is why we ask you to always list your Revit issue in your question.   The program does change every year and this feature was added in 2016.
The join you are pointing at is only for mullion conditions.
Walls used as curtain panels - stop joining
Mon, Feb 23, 2015 at 8:14:13 AM
raked curtain wall
Tue, Sep 23, 2008 at 2:09:20 PM
Butt-join Curtain wall
Mon, Sep 24, 2007 at 8:58:25 AM
Curtain wall to wall at an angle
Tue, Jun 12, 2018 at 2:38:49 PM
Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM
Page generation time: 2.1929
