24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Creating Furniture Schedule with Room Info from Linked Model
0 Posts No Rating |
Hi,
I'm working on a large school project, I have just populated the model with our FF&E requirements. However when I have all the components that I require loaded, over 3000's components, it significantly increases the size of the model. Our design team requested that we create a separate linked file.
I am now moving onto the stage of generating schedules for our Room Layout Sheets, but the FF&E Linked Model won’t recognise the room tags in the main model when I go to schedule it. I understand this has been a problem in the past from reading other threads, and I have tried many of the different solutions to solve this, but to no avail.
But a lot of these threads were dated 4+ years ago so I was wondering has anyone figured out any better or easier methods of doing it since?
Thanks
As with everything Revit, experiment FIRST! You need a thorough understanding of how Revit works before making major decisions.
If you are a consultant, then you should be in a seperate model. If you are all in the same office, a seperate model may not be the best choice. As you have belatedly found out, in order to report room association, the room has to be in the same model (or the items have to be where the rooms are).
So now for your choices....
- Your design team did not have all the answers. If your FF&E items had all been placed in a seperate workset, file size would be larger but working in the file would not have to change for other desciplines. Revit allows you to unload/load worksets at any time including on start-up. We use this to control large files.
- You can set the linked model to room bounding and add the rooms to your model. Is this good? NO! You will probably make mistakes and you have to manage this. I have never done this but wile working in your model, open a seperate DETACHED copy of the linked file, then per level, copy all rooms in this detached file and paste them aligned in your file (you might as well get the tags too). Repeat per floor level.
Hi Timmy
I think your best option is to use Dynamo. With Archilabs script it's possible to schedule with room awareness between linked files, and you can also get Dynamo to write the info back to your furniture.
14 Posts No Rating |
Is there anymore to this script? I am not seeing anything being populated in my schedule. It's not taking the rooms from the link.
Furniture in Host Model not recognizing Linked File Room Bounding |
Fri, Oct 4, 2013 at 7:02:23 AM
Creating Furniture Schedules with two files |
Tue, Mar 27, 2012 at 7:38:01 AM
Door schedule parameters not displaying "room names" from linked revit model. |
Fri, May 15, 2015 at 1:22:11 PM
Room schedule input when working from an Architectural linked file |
Wed, Mar 26, 2014 at 3:38:18 PM
Capturing room number and name data for casework, furniture, etc. |
Tue, Feb 2, 2010 at 6:14:40 AM
