Forums >> General Discussion >> Revit Project Management >> Saving a completely stripped file?
Wed, Apr 27, 2016 at 9:26:20 AM | Saving a completely stripped file?
pwoolson
I'm working on a project where the client wants a revit model but we aren't printing any sheets (so we don't need any details)
Is there a way to export the model so that the file doesn't containg any of our propriatary details, annotations, detail components, etc?
a Purge doesn't get rid of much
Wed, Apr 27, 2016 at 9:32:37 AM | Saving a completely stripped file?
If you don't want anything but the model including no dimensios etc then simply link the model into a blank project then bind it.
Wed, Apr 27, 2016 at 9:37:45 AM | Saving a completely stripped file?
pwoolson
When binding it, does that give them total access to the modeled elements?
Wed, Apr 27, 2016 at 9:41:35 AM | Saving a completely stripped file?
Yes, they have the model.... That was what you asked for.  They have no details, notes, dimensions - no annotative items at all but they do have the model.   You can not give them the model without giving them access.
Wed, Apr 27, 2016 at 9:47:15 AM | Saving a completely stripped file?
pwoolson
Thanks! That's exactly what I want.
The question about access was coming from when I link models. The linked model is a full model but I can't get in and change anything. But I think the binding cures that.
Wed, Apr 27, 2016 at 9:53:05 AM | Saving a completely stripped file?
Binding a Revit model it creates a group in the host project.  The whole model is a group so if you want to manipulate it, you should ungroup it then you will also want to delete the group from the bottom of your browser to compact the file.
Wed, Apr 27, 2016 at 9:57:34 AM | Saving a completely stripped file?
pwoolson
Very good. Thanks for the info. I really appreciate it!
Wed, Apr 27, 2016 at 11:50:43 AM | Saving a completely stripped file?
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
This suggestion is slightly different than what you're asking, but you can automate the extraction of a model or series of linked models for better transmitting of models to owners/clients/consultants.  Its called eTransmit for Revit.  It will automatically purge, detach from central, etc... and lets you select the options you want to do once you've "cleaned" your model.
Cheers!
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Saving Central files on local drive
Thu, Apr 2, 2009 at 4:23:55 PM
Saving to Central
Thu, Mar 12, 2009 at 9:42:05 PM
local file saving location [ 1 2 3 ]
Thu, Jul 10, 2008 at 8:03:09 AM
39
saving in previous releases
Wed, Oct 11, 2006 at 3:44:32 PM
Saving Elements to Separate Files
Thu, Feb 18, 2010 at 4:00:28 PM
Page generation time: 3.1069
