Forums >> Revit Building >> Technical Support >> Ceiling visbility
Sun, Apr 9, 2006 at 11:06:04 AM | Ceiling visbility
hammer87
hammer87 Avatar
3 Stars: 4 Votes
im trying to put a ceiling in, but i doesnt show up in the celing plan view. i get a messeage that says to check the visblity setting and all that., which i did and still no luck. need help asap.
Mon, Apr 10, 2006 at 6:22:39 PM | RE: Ceiling visbility
archdan
3.5 Stars: 2 Votes
I would check the view range, as it may be cropped out of the view. Either your cut plane is too high or your view depth and top view clipping plane are too low.
Tue, Apr 11, 2006 at 6:28:53 AM | RE: Ceiling visbility
hammer87
hammer87 Avatar
3 Stars: 4 Votes
well their both set to the 2nd level. the view depth is 0' 0" as well as the top cut plane.
Tue, Apr 11, 2006 at 12:16:43 PM | RE: Ceiling visbility
archdan
3.5 Stars: 2 Votes
When you say second level I presume that you are saying that it is the level above. If it is then those visibility settings should work assuming the ceiling is below the second level. This may seem basic, but have you checked that it is actually placing the ceiling. I thought that I had problems in the past where it would say to check the visibility settings but it would not place an instance of family or ceiling. Check with a camera view or section.
Wed, Apr 12, 2006 at 7:21:37 AM | RE: Ceiling visbility
hammer87
hammer87 Avatar
3 Stars: 4 Votes
yes i it was actually placing the ceiling. i checked it in the 3D view. it just doesnt show up in the ceiling plan.
Restroom Stall Visbility
Wed, Mar 2, 2016 at 10:47:30 AM
Ceiling objects cut by walls
Fri, Nov 20, 2009 at 12:58:09 AM
Lighting without ceiling
Thu, Sep 10, 2009 at 11:02:50 AM
awkward shaped ceiling
Fri, Mar 6, 2009 at 3:36:13 AM
How do i put a ceiling fan on the ceiling?
Tue, Jun 26, 2018 at 3:43:23 PM
Page generation time: 0.0814
