Forums >> Revit Structure >> Technical Support >> Need Help on Sloped Beam-Column Connection
Sat, Apr 23, 2016 at 10:11:47 AM | Need Help on Sloped Beam-Column Connection
jaiemm
Hi,
I'm having a problem on how to have a nice connection between a sloped steel beam and a steel column. I was wondering if it is possble to make the ends of the beams highlighted in the attached photo, to be cut vertically?
Thanks in advance!
Fri, Apr 29, 2016 at 1:50:43 PM | Need Help on Sloped Beam-Column Connection
Johnzo142
Use the coping tool.
Modify tab/Geometry/Cope
Edited on: Fri, Apr 29, 2016 at 1:55:43 PM
Edited on: Fri, Apr 29, 2016 at 1:58:43 PM
Edited on: Fri, Apr 29, 2016 at 1:59:14 PM
column-beam connection
Tue, Jan 12, 2010 at 5:46:46 AM
How to show beam column connection in plan properly
Fri, Nov 7, 2014 at 12:53:30 PM
Sloped Beam Connection
Thu, Feb 21, 2013 at 11:13:15 AM
Cut a sloped beam
Fri, May 11, 2012 at 3:48:19 AM
Column to diagonal beam/brace connection problem
Fri, Apr 23, 2010 at 4:40:24 AM
Page generation time: 0.3797
