Forums >> Revit Structure >> Technical Support >> Beams won't intersect or close-up to Structural Columns. Solution ?
Sat, Apr 23, 2016 at 5:49:44 AM | Beams won't intersect or close-up to Structural Columns. Solution ?
sentinelly
Hi everyone, i've just been using Revit for 2 months now. Maybe i've been stuck with this problem for that same amount of time. Here's the problem :
No matter what i try, Concrete Beams won't ever do what i want : intersect to the Structural Concrete Columns, or close-up to them. What they always always do is stop at the columns and offset from them with a consistent distance of 13mm.
The only way i could find out is "Disallow Join" every single Beam, and then move it to the specific spot i want, which i find very time-consuming.
I find that Architectural Columns would allow what i need, but then again i need Structural Concrete Columns instead. My boss don't allow me to paint Architectural Columns with Concrete material either Sad.
I would like to ask everyone around here if, there is any way to allow beams join close-up to structural columns, or intersect with them too ?
Tue, Oct 18, 2016 at 2:01:11 PM | Beams won't intersect or close-up to Structural Columns. Solution ?
sllana
5 Stars: 2 Votes
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-D041CD85-9AEC-40C9-B991-AA6D00EEE4ED
Columns/Beams won't cut wall & wall beyond is visible
Thu, Jun 21, 2012 at 9:19:31 AM
Attaching structural columns to beams - mitered joint?
Mon, Nov 15, 2010 at 3:37:44 PM
Concrete Columns and Beams cuts through wall...
Mon, Feb 4, 2013 at 8:10:15 AM
Structural Beams Questions
Sat, Sep 8, 2007 at 1:48:33 AM
Can't select beams nor columns
Sun, Mar 10, 2019 at 10:12:36 PM
Page generation time: 0.6124
