11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Newbies question about Revit
So I have this autocad site plan that I have to draw on Revit.
I drew the property lines, and created the topography revit with the exact dimensions as the autocad file. But when I look at the elevations, my levels are way below. How do I fix this. I tried playing with the Project Base Point elevation, but its not working. When I created my topo, I inserted the points, and changed the elevations to what the autocad file says. Am I doing it right?
How do I make GRADE level the same level as my topography.
Simple way (but not always the best) is to goto an elevation view. Dimension lock your levels. Then either:
- Change your base level reference from project to survey then change the elevation value on the level
- Select the reference level and move it up the distance it needs to move.
Newbies |
Wed, Jul 20, 2011 at 3:10:25 AM
Newbies in Revit Structure |
Sun, Mar 2, 2008 at 6:49:57 AM
Learning Revit for Newbies!! |
Tue, May 15, 2012 at 7:52:43 AM
u-bolt creating_newbie revit modeler |
Mon, Jun 18, 2018 at 10:53:55 AM
Newbie - How to Link consultant's revit files? what to use for position? |
Thu, Jul 23, 2009 at 5:43:47 PM
