Forums >> Workflow & Implementation >> API & Third Party Apps >> Revit to 3DS Max and creating FBX files
Mon, Apr 18, 2016 at 2:58:13 PM | Revit to 3DS Max and creating FBX files
AlexBean
I have just started to learn 3DS Max for rendering the models I have created in Revit. I am trying to use the Workflow Suite however whenever I click 'Run' nothing happens, the dialog box shuts and 3DS Max doesn't open. I have also tried to get my model into 3DS by exporting as a FBX file however whenever I try this, I click export and again nothing happens, there is no file created when I look in My Documents.
I have Revit 2015 and 3DS Max Design 2015, both the student versions.
Any help would be much appreciated.
Thanks
Wed, Aug 10, 2016 at 6:13:17 PM | Revit to 3DS Max and creating FBX files
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I'm not sure about the student versions and this process but I could refer you to this thread I recently posted to:
http://www.revitcity.com/forums.php?action=viewthread&thread_id=36509
Fri, Apr 26, 2024 at 4:30:41 AM | Revit to 3DS Max and creating FBX files
flix123
flix123 Avatar
To transfer models from Revit to 3DS Max and create FBX files, export the Revit model as an FBX file. Then, import the FBX file into 3DS Max and adjust materials and textures as needed before exporting as a final FBX.
Edited on: Thu, Apr 25, 2024 at 11:35:45 PM
Edited on: Fri, Apr 26, 2024 at 5:02:22 AM
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:27 PM
Exporting FBX file from Revit to 3Ds Max
Wed, Sep 30, 2020 at 1:36:49 PM
.ies files from Revit export to 3Ds Max rotate incorrectly
Wed, Aug 19, 2009 at 2:06:14 PM
FBX or DWG
Mon, Dec 22, 2008 at 4:13:18 PM
problems with Revit 2013 in 3ds Max!
Fri, Dec 14, 2012 at 4:25:44 PM
13
Page generation time: 3.4333
