Forums >> Revit Building >> Technical Support >> wall wrapping at curtain wall "inserts"
Fri, Apr 7, 2006 at 5:13:24 PM | wall wrapping at curtain wall "inserts"
mhildebrandt
Anyone know how to make a wall layer wrap at a curtain wall "insert"? We have large glass wall openings in our solid wall that I made by cutting geometry, but the solid wall's layers don't wrap as they do at a normal hosted window.
Tue, Apr 11, 2006 at 2:00:21 AM | RE: wall wrapping at curtain wall "inserts"
fazerneil
4 Stars: 5 Votes
have you tried setting wall ends to wrap ?
Tue, Apr 11, 2006 at 11:57:18 AM | RE: wall wrapping at curtain wall "inserts"
mhildebrandt
yes, but that doesn't affect these. Revit apparently doesn't regonize curtain walls as inserts.
Tue, May 20, 2008 at 2:08:48 AM | wall wrapping at curtain wall "inserts"
Arno
aren't there more people with this problem, or is the solusion that simple...please reply..
can't find more threads on the subject.
Tue, May 20, 2008 at 4:20:11 AM | wall wrapping at curtain wall "inserts"
4 Stars: 205 Votes
Hi "mhildebrandt", do you create your wall by a normal "system wall family" or "create in place" a mass like a wall then "Cut" the mass where the curtain is placed?
Tue, May 20, 2008 at 6:29:51 AM | wall wrapping at curtain wall "inserts"
4 Stars: 205 Votes
I do by the two systems i told before and it's work...
wall layers not wrapping at curtain wall inserts!
Fri, Mar 4, 2016 at 10:27:08 PM
Wall Wrapping at Inserted Wall
Thu, Aug 27, 2009 at 8:44:18 AM
WALL WRAPPING AT INSERTS PROBLEM
Thu, Jan 29, 2015 at 6:56:17 AM
wrapping of wall inserts
Fri, Jul 14, 2006 at 5:13:18 PM
wall wrapping problems
Wed, Mar 4, 2015 at 9:59:02 AM
Page generation time: 1.0351
