Forums >> Revit Systems >> Technical Support >> render run slow
Thu, Apr 14, 2016 at 7:44:03 AM | render run slow
mirone
HELLO,
i heve a big project (Final Project for College )
 and i have few render i must to make.
my pc HW:
I7 4790  3.6 ghz  32 GB ramand HD ssd (flash hard diskand wd 7200rpm the project is on the ssd drive)is that normal that one render take  me  more than 6h?printer 150 DPI  high resolotion)(it's take time to get a good "Balance control" THE FILE IS heavy...if it's influencing(i make some componnent)(my revit ver as i REVIT 15)i don't spek english so use a simple english please
Thu, Apr 14, 2016 at 8:25:59 AM | render run slow
מיר זאל זיין בעסער אַוועק דורך ניצן Google זעץ.עס איז מער צו ופפירן צייַט ווי קאָמפּיוטער. פיל דעפּענדס אויף ווי איר מאַדאַלד. איז דעם ינלענדיש אָדער יקסטיריער? זון בלויז אָדער קינסטלעך לייטינג?ביימער און געקשאַק זענען שרעקלעך ופפירן כאַגז.אויב דאָס איז יקסטיריער, טאָן איר נאָך האָבן ינלענדיש זאכן אַז זאל זיין גענומען אַרויף ופפירן צייַט? מיר שטעלן אַלע ינלענדיש אויף אַ ינלענדיש וואָרקסעט און אומקערן אַז אַוועק.
Thu, Apr 14, 2016 at 9:17:08 AM | render run slow
marmiketin1
4.5 Stars: 10 Votes
If you want the render to be of good quality and you are only able to render using revit then yes it will always take several hours at the minimum.
Thu, Apr 14, 2016 at 10:39:12 PM | render run slow
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
That sounds about right.  While you do have a fast processor, you only have one.
Either link your Revit into 3dsMax
or
Buy a professional workstation with dual Xeon processors on board, 10Cores per processor minimum if you're serious about rendering.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Fri, Apr 15, 2016 at 7:49:43 AM | render run slow
mirone
ware i can find a good Work station ?hp/Dell/els?what is the price for WS and wich one you suggest?my pc cost me  1500$ few month ago (with good hardware)
more than 10 hr to get 76%? lock somting not going wellif i purge  the file it can help??wwhub, i can't read your commentthank you
Making Revit run better.
Thu, Jun 28, 2012 at 7:25:21 AM
Rendering slow in 2009
Mon, Apr 20, 2009 at 6:40:53 AM
Really Really slow render time......
Thu, Oct 30, 2008 at 5:09:59 AM
Maps and Render Times
Mon, Feb 8, 2010 at 3:54:44 PM
Rendering slow with Mental Ray - try ray tracer?
Thu, Apr 14, 2016 at 10:43:53 PM
Page generation time: 0.5352
