Forums >> Revit Building >> Technical Support >> Wall Types - floor plan vs. elevations/sections
Fri, Apr 7, 2006 at 2:29:51 PM | Wall Types - floor plan vs. elevations/sections
Live2Dive
Hi there. I am new to Revit (one month) and am trying to convert my office (and mind) from Autocad to Revit. I am a residential architect nad have been so for 15 plus years. Here is my question. It has to deal with wall types. When using basic Autocad, I would typically draw my walls in plan at their true width, ie: 2x4= 3 1/2". In section, I would add the thickness of the finishes (gyp board, exterior sheathing, etc...) I can see how Revit can save so much time when it comes to sections and elevations. But, in plan, it shows all those lines for the materials. Is there a way to turn those off so that I do not see them in plan, but still have them there for sections and details. It really is driving me up the wall. I do not want to plot with them showing on plan, nor dor I want to see them as I am working on the plan. I hope this is not a stupid question, but my mind is still trying to convert from 2D to 3D thinking. Thanks in advance...
Fri, Apr 7, 2006 at 2:34:10 PM | RE: Wall Types - floor plan vs. elevations/sections
coreed
coreed Avatar
4 Stars: 16 Votes
in plan set your detail level to coarse and it will display only two lines representing the widith of the wall best regards, coreed,aia Post edited on 2006-04-07 14:34:57
Fri, Apr 7, 2006 at 2:39:00 PM | RE: Wall Types - floor plan vs. elevations/sections
Live2Dive
I've done that, and it does show just the two lines, but the thickness for the exterior walls shows the face of the finish levels. I just want the plan to show the basic core, and not the finishes. Does that make sense?
Fri, Apr 7, 2006 at 4:38:46 PM | RE: Wall Types - floor plan vs. elevations/sections
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is kind've against the thinking of revit, however you could achieve this by using override host layers in your plan view (visibility settings) and making your finish layer a white line, thus rendering it invisible. HTH.
Floor plan types
Thu, Nov 13, 2008 at 9:51:17 AM
IS IT POSSIBLE TO SPOT ELEVATIONS OF A WALL IN A FLOOR PLAN?
Tue, Jan 25, 2011 at 1:25:12 PM
3 elevations 1 floor plan
Tue, May 15, 2007 at 7:13:01 AM
Wall sections cut from elevation... now not seen on plan
Fri, Mar 9, 2012 at 11:05:12 AM
Residential Wall Types
Sun, Mar 21, 2010 at 11:30:11 AM
Page generation time: 1.7681
