Forums >> Revit Building >> Technical Support >> enlarge control dots on dimension witness line?
Thu, Apr 7, 2016 at 5:12:03 PM | enlarge control dots on dimension witness line?
KennedyDrafting
Is there a way to make the control dots on the witness lines of the dimensions larger?
Thanks
Fri, Apr 8, 2016 at 10:21:15 AM | enlarge control dots on dimension witness line?
Do you mean regular dimensions? Manage / additional settings / arrowheads / your tick / tick size.
Do you mean temporary dimensions?  Revit R dropdown/options/graphics/temporary dimensions text size
Fri, Apr 8, 2016 at 10:42:45 AM | enlarge control dots on dimension witness line?
KennedyDrafting
That's not what I am asking.    See attached pdf.
To move a "regular" dimesnion's witness line, you click on the witness line and drag the small dot (control dot) to the place you want the dim to be measured from.
My questions is how to make that small control dot larger?
Fri, Apr 8, 2016 at 10:47:51 AM | enlarge control dots on dimension witness line?
Sorry - No way that I have seen or even read about.
Dimension witness line snaps??
Wed, Mar 28, 2012 at 1:12:09 PM
Dimension Text Problem
Fri, Nov 14, 2008 at 9:41:55 PM
Dimensions & Crop Regions
Mon, Sep 18, 2006 at 9:56:41 PM
Trimming multiple witness lines?
Wed, Jan 14, 2009 at 2:35:48 PM
Dimension Arrows/Ticks/Dots
Thu, Oct 23, 2008 at 7:31:45 AM
Page generation time: 0.5035
