Forums >> Revit Building >> Technical Support >> Customize tick sizes
Thu, Apr 7, 2016 at 5:21:05 AM | Customize tick sizes
GLKIRK
Thanks for all the help over the years!
Can tick sizes be customized in 2013?
Thanks!
Gary
Thu, Apr 7, 2016 at 7:42:48 AM | Customize tick sizes
As with most things in Revit, an answer is in your HELP.
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-E3C2E74A-C5B0-4A59-A5BE-53E2D4937B49
Thu, Apr 7, 2016 at 1:07:54 PM | Customize tick sizes
GLKIRK
Thanks again WWHub,
I have been there a half dozen times and can not find a way of changing much except to be able to pich from the choices.
In the meantime, I have found a way that works good. Since the view to be shown is very small, I/we can bump the scale way up (3/4" in this case), and with cropping and adjusting text size, I/we can make a very presentable view.
Thanks again,
Gary
Thu, Apr 7, 2016 at 2:52:42 PM | Customize tick sizes
You only asked if you could modify the dimension tick and the help tells you how to do that.   True, you can't create a funky arrowhead but we have managed to create several different ones that we use.
custom tick marks
Sun, Dec 9, 2007 at 12:35:48 PM
How do I create a custom Tick Mark Parameter?
Mon, Aug 13, 2007 at 8:34:45 AM
customize dimensions?
Mon, Sep 19, 2016 at 2:13:56 PM
Heavy End Tick Marks disappear
Thu, Jul 15, 2010 at 1:55:44 PM
dimension tick
Wed, May 5, 2010 at 8:08:41 AM
Page generation time: 0.5762
