20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Strategy for Continuous Handrail on Stair at multiple floor heights.
Does anyone have a good method for creating a stair that has multiple floor levels and a continuous handrail? The caveat is that the floor heights don't share a common riser height denominator. Any insight on this would be helpful. Thanks!
Its tricky to successfully get a handrail to do everything you need especially where it ascends up a stair case at an angle and then continuous on the next level on top of itself. Its also confusing to you and Revit.
Sometimes you just have to create the stair and railings from separate individual parts and have them meet at a common face. Visually the separate parts will appear correctly in plan, section and elevation but in reality they are "lego pieces".
I hear ya about the seperate parts. What have you typically done? Create seperate handrails, modify extensions...I've been finding that I cannot quite get these to meet at common faces at every instance which makes the overall appearance a bit sloppy. Let me know if you have a good procedure in this case. Thanks so much for your reply!
Stairs with multiple levels and varried floor to floor heights in Revit |
Tue, Sep 17, 2013 at 12:37:24 PM
Non-continuous handrails at stairs |
Thu, Jan 25, 2018 at 11:34:45 AM
Handrail Extension at Top of Stair |
Thu, Jul 2, 2020 at 7:32:23 AM
Interrupted Guardrail with Continuous Handrail - Revit 2013 |
Thu, Feb 20, 2014 at 12:16:31 PM
Starting a Rail on the stair landing. |
Thu, Dec 19, 2013 at 3:01:59 PM
