Forums >> Revit Structure >> Technical Support >> Can I make formulas in a family without a bunch of parameters showing up
Mon, Apr 4, 2016 at 7:30:11 AM | Can I make formulas in a family without a bunch of parameters showing up
rgkjr
Is there a way to create a family and control the geometry without seeing all of the parameters in the revet project?
2D detail item, say you have a box controlled by 2 parameters H & W.
Now say you want to round the corners of this box and you want the radius to be 10% of H.
Normally I would create a parameter for the radius and place my formula there, easy enough but
how can I hide this extra parameter from the user after they have loaded the family into revit since they do not need
to see it?
This is a simple example, it would be nice not to show a large list of parameters to the user.
Thanks
Mon, Apr 4, 2016 at 10:32:08 AM | Can I make formulas in a family without a bunch of parameters showing up
Shatner86
Shatner86 Avatar
5 Stars: 2 Votes
hey rgkjr,
I was actually reading something on this recently. There is a way to create a shared parameter file that contain parameters that can be hidden within the project environment but visible in the family editor.
See this guide by "The Fluffy Kitten"
http://blog.discoverunifi.com/hidden-parameters-the-key-under-the-mat/
Kind Regards,
Shatner86
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein
Mon, Apr 4, 2016 at 11:11:07 AM | Can I make formulas in a family without a bunch of parameters showing up
rgkjr
Thanks I'll look into that.
RK
Mon, Apr 4, 2016 at 1:38:24 PM | Can I make formulas in a family without a bunch of parameters showing up
rgkjr
Ok, I figured it out.
Make a family with all of the parameters you want.
Make the parameters you want to show to the user "instance" parameters then nest this one into a final family and connect
the shared parameters all of the others are controlled in the background.
RK
to import shared parameters with formulas.
Fri, Jun 20, 2014 at 7:19:05 AM
controlling visibility with parameters
Wed, Dec 31, 2008 at 11:53:55 AM
HELP WITH FAMILY PARAMETERS AND FORMULAS!
Mon, Jan 2, 2012 at 2:11:05 PM
Parameter Formulas
Wed, Mar 21, 2007 at 12:48:43 PM
Understanding Formulas
Tue, Nov 16, 2010 at 1:36:05 PM
14
Page generation time: 1.0013
