Forums >> Revit Building >> Technical Support >> Problem with filled region
Fri, Apr 1, 2016 at 11:38:58 PM | Problem with filled region
gkp7929
2.5 Stars: 2 Votes
Hi guys, i got a problem..I'm working on a ceiling view..i want to show some mep devices in this ceiling view.
Problem stated when i added a grey solid filled region to show the non scope area in that view.
My view is in wireframe and i have put the filled region in transperant.
But when i take a print or print preview the filled region is not showing the mep fixture under that.
I even tried adding filter to the filled region to make it more lighter and transperant.
can some one help me out from this?
Many Thanks  in Advance
Mon, Apr 4, 2016 at 11:26:17 AM | Problem with filled region
marmiketin1
4.5 Stars: 10 Votes
It would be helpful if you posted a screenshot of the filled region along with the settings associated with it. You could try selecting the region, right clisking and then override graphics by element. then change the surface transparency to 50% as the default is going to be 0%
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
filled region pattern color changes when drawing scale changes
Thu, Apr 14, 2016 at 7:32:06 AM
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Deleting Types From Filled Region Families
Tue, Sep 9, 2008 at 6:56:41 PM
Filled Region
Mon, Apr 2, 2012 at 9:48:42 PM
Page generation time: 2.8963
