Forums >> Revit Building >> Technical Support >> Component by Extrusion - Chair Above Table
Sun, Mar 27, 2016 at 5:17:00 PM | Component by Extrusion - Chair Above Table
enzotessi
Hi folks!
Really simple question here. I've created a new desk by extrusion. The only problem I'm having is that the chairs will show as if they were above it when I'm in a floor plan. Any ideas?
Cheers,
Enzo
Mon, Mar 28, 2016 at 7:03:38 AM | Component by Extrusion - Chair Above Table
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are the chairs actually above it?  Do the chairs have detail lines that are being used to show in plan?
Mon, Mar 28, 2016 at 7:03:44 AM | Component by Extrusion - Chair Above Table
The problem is your families.
Is your table's solids set to show in plan views or only symbollic lines?
Same question for chair.
If both family's model elements are set to show in plan view then cut a section and check out heights.
Mon, Mar 28, 2016 at 9:35:44 AM | Component by Extrusion - Chair Above Table
enzotessi
The chairs are hosted on the floor, and touching it, so it isn't actually above the table. I didn't model the chairs (Herman Miller), so I'm guessing the problem isn't there.
WWHub, it might be set to show only symbolic lines, but how can I check that?
Mon, Mar 28, 2016 at 12:03:03 PM | Component by Extrusion - Chair Above Table
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to open the family, go into the "floor plan" view in the model and see if there are symbolic lines.
How to create void extrusion running on 2 different planes on furniture???
Mon, Aug 29, 2011 at 8:22:33 AM
nested families
Thu, Aug 2, 2012 at 3:43:20 AM
table and chairs
Thu, Apr 29, 2010 at 7:35:01 PM
Model Group Materials Help!!
Fri, Oct 9, 2020 at 4:14:23 PM
Transparent Table in plan
Thu, Jan 13, 2011 at 2:37:30 PM
Page generation time: 0.2752
