Forums >> Revit Building >> Technical Support >> Arrays and Paramedics... I mean Parametrics
Fri, Apr 7, 2006 at 6:59:13 AM | Arrays and Paramedics... I mean Parametrics
rkitect
rkitect Avatar
4 Stars: 29 Votes
Hi there, I was hoping someone could take a look at this family and tell me if the Parameters are acting ok for them. When in Family Editor, everything works fine. However, when I put it in a project, I get this: http://tinypic.com/view/?pic=t6yzrr There's supposed to be a 1/4" gap between each cd. I think what's getting lost is the parameter "Plus Spacing" that is supposed to define how far from the edge the first and last CD of the array are. Bonus side question... why is it that even with Shininess to 0 and "No Object Reflections" turned off, this things still looks like it has more chrome than the ship from "Flight of the Navigator?"
Sat, Apr 8, 2006 at 8:18:48 PM | RE: Arrays and Paramedics... I mean Parametrics
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hi, Unforunately this site is still having issues and forbidding me to download attachments so i can't look at your family... Things to check: With your array make sure your disks are a nested family. this will make them easier to control Make sure you have constrained them off their origin (the reference planes that are set to define origin in the family). This should resolve your issues with the array. How high do you have reflectivity turned up?
Sat, Apr 8, 2006 at 9:22:17 PM | RE: Arrays and Paramedics... I mean Parametrics
hammer87
hammer87 Avatar
3 Stars: 4 Votes
just relating that im to having issues openig attachments Post edited on 2006-04-09 20:35:00
Sat, Apr 8, 2006 at 11:09:55 PM | RE: Arrays and Paramedics... I mean Parametrics
rkitect
rkitect Avatar
4 Stars: 29 Votes
I'm not able to test the origin offsets (currently the disc is offset from the edge of the stereo which is set to flex based on the number of CDs parameter using a formula. Part of the problem may also be that the disc is not nested family but instead an extrusion that is arrayed using a formula to control spacing and such. I tried a nested family but could not get the family editor to allow me to rotate the cd family.. Like it was frozen to the plane it was created on. Reflectivity is set to a whopping 0!!! However, in an attempt to create a material similar to the beloved apple line of products, there is a 1/16" thick extrusion of an "acrylic" material wrapped around the main material. I haven't played with it yet enough between power outages and bad weather and getting my car street ready i haven't had much time Thanks for the help. I hope admin gets this attachment deali-o fixed soon. Post edited on 2006-04-08 23:14:24
Sun, Apr 9, 2006 at 6:48:49 PM | RE: Arrays and Paramedics... I mean Parametrics
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You'll need to create the nest family discs on the correct plane to begin with. Create an extrusion based on a reference plane at the same angle. HTH.
Revit 2009: Familly with parametric arrays - Voids wont cut
Tue, Aug 19, 2008 at 3:46:02 PM
Casework and Family Editor Repeating Detail
Fri, Jun 30, 2006 at 1:38:59 PM
Trouble with void forms and parametrics in families
Mon, Jul 4, 2011 at 9:28:29 AM
Parametric Arrays - Detail Item Help!
Fri, Jan 29, 2021 at 9:03:59 AM
radial arrays
Sun, Aug 1, 2004 at 4:22:13 PM
Page generation time: 1.3271
