Forums >> Revit Systems >> Technical Support >> Actual Columns with proper sizing?? Where do I get these?
Thu, Mar 24, 2016 at 9:40:48 AM | Actual Columns with proper sizing?? Where do I get these?
NeoBahamut
Why does revit not provide typical columns sizes avaiable like CAD does with the detail manager? I can understand not pre loading them but they don't provide any to load in.
Thu, Mar 24, 2016 at 10:29:52 AM | Actual Columns with proper sizing?? Where do I get these?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'm assuming you are not looking in the right spot because they do.
Thu, Mar 24, 2016 at 2:18:42 PM | teafoe5
NeoBahamut
Quoting teafoe5 from 2016-03-24 10:29:52
I meant 3D families that you can load in like Detail Components.  Not detail components themselves.  I am dropping in steel and concrete structure in the model of an existing building.
In each family, there are only a few column types of different sizes.  I don't feel like punching in numbers and creating new ones.  I don't have a steel manual.
Thu, Mar 24, 2016 at 2:29:47 PM | Actual Columns with proper sizing?? Where do I get these?
I have several pages of steel columns in my stock library.   See image
You don't seem to be using the correct process.  Pick structural column in your project then load, then pick structural columns in the library, then column type - etc.
Thu, Mar 24, 2016 at 2:35:44 PM | Actual Columns with proper sizing?? Where do I get these?
NeoBahamut
I do not get that library.  I just get the last column I placed in after clicking on structural column.
Thu, Mar 24, 2016 at 2:43:58 PM | Actual Columns with proper sizing?? Where do I get these?
NeoBahamut
The attached pic shows that I only have 2 types loaded in the project.
Thu, Mar 24, 2016 at 4:07:02 PM | Actual Columns with proper sizing?? Where do I get these?
Please do as I have posted ....   YOU HAVE TO LOAD MORE!
Fri, Mar 25, 2016 at 8:30:21 AM | Actual Columns with proper sizing?? Where do I get these?
You have to pay attention to your menu options.
Pipe sizing in Revit.
Tue, May 6, 2014 at 7:00:56 AM
HB&G Columns
Thu, Jan 22, 2009 at 4:30:03 PM
columns wont host to level
Tue, Feb 27, 2018 at 3:59:01 PM
COLUMNS CAST WRONG SHADOWS
Mon, Sep 7, 2015 at 1:05:36 PM
Auto-Sizing Schedules
Thu, Jul 30, 2015 at 3:30:28 PM
Page generation time: 0.1544
