27 Users Online (25 Members):
Forums >> Revit Systems >> Technical Support >> Linked Architectural Model
0 Posts No Rating |
Can anyone help?
When I link an Architectural model into my Systems Template, it appears but all the elements are transparent. This is very helpful for installing M&E equipment, but, occasionally I would like to do a walkthrough for clients and would like to be able to turn on the materials that have been applied to the architectural model, but do it within the Systems Template which includes my M&E services.
Can this be done? If so, how?
Thanks guys.
I have never seen a file linked into a template and I'm sure that is not supported. Did you really mean this or did you mean linked into your project that was created using your systems template?
Change you view to coordination and see what happens.
0 Posts No Rating |
Hi, apologies, I have created a new project using the Systems Template. When I then link the Architectural (.rvt) file into my project, is when all the elements are transparent and I cannot see the materials.
We try very hard to anser user questions but it all seems to be wasted when they don't read our answers.
As I wrote "Change you view to coordination and see what happens." It's in view properties - view discipline.
0 Posts No Rating |
Apologies again, I was only trying to explain myself correctly and you help has solved my issue and all is good with the world now so thanks.
Rooms not displaying from linked architectural model - Revit 2018 |
Thu, Jan 17, 2019 at 2:41:26 PM
visibility of reinforcing from linked structural model in architectural sections |
Thu, May 29, 2008 at 3:44:37 PM
Linked Revit Model Sheets |
Fri, Apr 5, 2013 at 12:04:28 PM
Linked Model - Losing only some doors from linked model |
Thu, Oct 21, 2010 at 1:52:14 PM
"Lock/Pin" Linked Architectural Model |
Fri, Feb 11, 2011 at 10:13:52 AM
