Forums >> Revit Building >> Technical Support >> Steel beam views
Mon, Mar 21, 2016 at 5:43:35 PM | Steel beam views
LDMdrafting
I am looking for a faster way to set up views for creating shop drawings for the steel beams in our buildings. (We are currently not using advance steel)
Our engineer likes to have the views set up so that instead of the camera rotating around the beam the beam rotates infront of the camera so the one end is always on the left side. I have been able to do this by creating an elevation of each side. Then creating a callout of one elevation and rotating that. On top of that I also have to create individual top and bottom views for each beam. While this works it is tedious to set up especially when there are multiple beams.
Does anyone have any suggestions?
Fri, Apr 1, 2016 at 3:08:27 PM | Steel beam views
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Assemblies and Assembly views ?
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:36 PM
Detailing a Beam Saddle at Valley Beam
Wed, Jan 26, 2011 at 12:15:21 PM
revit steel questions
Mon, Apr 6, 2015 at 9:27:20 AM
Fabsec Steel Beam Families
Wed, Nov 8, 2006 at 1:43:28 PM
Steel beam to steel/concrete column fixture (Noob question)
Wed, Feb 27, 2013 at 3:18:10 PM
Page generation time: 0.4016
