Forums >> Workflow & Implementation >> API & Third Party Apps >> Add size_lookup formula via Revit API
Mon, Mar 21, 2016 at 8:53:25 AM | Add size_lookup formula via Revit API
JoostvZ
Hi guys,
I'm using the FamilySizeTableManager Revit API class to load a CSV file into my family, which works. When I open the family in Revit afterwards, I can enter formulas to use the lookup table: "size_lookup("MyLookupTable", "L1", 20 mm, D1, D2, ANGLE)".
But I'm not able to enter the same size_lookup formula via the API. When I call:
FamilyManager.SetFormula( parameter, "size_lookup(\"MyLookupTable\", \"L1\", 20 mm, D1, D2, ANGLE)" );
the API returns "It is an invalid formula string. Parameter name: formula". I've also tried single quotes, but with no luck. What am I doing wrong?
Programming macros with the revit API
Wed, Feb 1, 2012 at 4:33:56 AM
WorksetExplorer for Revit 2013
Wed, Mar 20, 2013 at 9:48:16 AM
Revit 2013 API
Mon, Dec 31, 2012 at 10:32:36 AM
Add 2 to Parameter Formula
Fri, Nov 9, 2007 at 1:06:13 PM
RemoveEmptyTags Revit API Tool from dp Stuff
Tue, Mar 26, 2013 at 7:14:26 AM
Page generation time: 1.8877
