Forums >> Revit Building >> Technical Support >> Import existing Revit Building in New Project
Fri, Mar 18, 2016 at 2:57:54 PM | Import existing Revit Building in New Project
PhilVonPer
Hey guys, I have a question. I have already built a couple houses, but me and a couple friends opened up a new project, where we're working with workshare. It's everything working, but a few guys, including me, wondered if we can import our existing houses into the central model, because we want to build a small town/neighborhood.
Could anybody help us with that or tell us, if it works, how?
Thanks, Phil
Fri, Mar 18, 2016 at 3:21:56 PM | Import existing Revit Building in New Project
Don't import, link in your other models.
Wed, Mar 30, 2016 at 10:59:03 AM | Import existing Revit Building in New Project
PhilVonPer
Are our houses in that project going to be visible and editable?
Wed, Mar 30, 2016 at 12:47:34 PM | Import existing Revit Building in New Project
Linked projects are all editable in their own project.   In a composite model with seperate linked projects, all of the linked models can be seen and visually controlled, individually but can no be edited there.
Wed, Mar 30, 2016 at 2:07:32 PM | Import existing Revit Building in New Project
PhilVonPer
Ok
If I edit the linked file in its original file, is it gonna update in the composite file?
Wed, Mar 30, 2016 at 2:09:30 PM | Import existing Revit Building in New Project
As long as you link, not insert.  Do you understand that difference?   If not, you can / should learn more by reading about linking in your HELP.  That's why it is there.
Thu, Apr 7, 2016 at 12:55:01 PM | Import existing Revit Building in New Project
PhilVonPer
Alright thanks
Should i use the existing Revit Model to create a new building addition?
Tue, Apr 19, 2011 at 8:07:22 AM
Moving an existing building without demolishing and rebuilding it
Thu, Nov 14, 2013 at 6:57:42 AM
existing building at an angle.
Mon, Jul 1, 2013 at 7:45:19 AM
Exisiting building linked model display
Mon, May 15, 2017 at 7:10:24 AM
Stupid ? # 234 - project browser
Fri, Nov 20, 2009 at 1:23:50 PM
Page generation time: 4.8379
