Forums >> Revit Building >> Technical Support >> sheet index order with Linked models
Fri, Mar 11, 2016 at 2:33:53 PM | sheet index order with Linked models
ledgewood33
I have figured out how to show the sheets from linked models. the problem I am having now is getting those linked model sheets to show in my sheet index in the correct order. within my revit model I have parameters set up to sort the sheets i.e. DISCIPLINE & DISCIPLINE ORDER. when I am in the "edit schedule" view and I try to populat those columns from the linked model sheets it doesnt allow me.
any suggestions?
Sun, Mar 13, 2016 at 12:37:27 PM | sheet index order with Linked models
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
You might have to split the drawing lists into seperate schedules ?
Combined Sheet Index with Linked Consultant Models
Tue, Apr 8, 2014 at 2:04:46 PM
SHEET INDEX ORDER
Sat, Dec 12, 2009 at 9:14:52 AM
Links to each sheet in sheet index
Sun, Aug 21, 2016 at 11:06:31 AM
Combine multiple sheets into a single PDF file per THE SHEET INDEX
Fri, Jul 31, 2015 at 3:00:27 PM
sheet index (list) not organizing properly
Thu, Sep 15, 2016 at 4:13:55 PM
Page generation time: 1.7931
