Forums >> Revit Systems >> Technical Support >> View range-top
Fri, Mar 11, 2016 at 12:39:26 PM | View range-top
palowe
Hi
I like to do in my egress plan a cut plane at 4' above associated level, and then I want to set the top level to see the reflected ceiling plan, so I can see overlaid the exit signs and emergency lights above. I'n changing the top clip and nothing works, nothings changes... really annoying
Only changing the cut plan shows them, but then I don't see the doors cut. Underlay RCP doesn't work either.
Thanks,
Sun, Mar 13, 2016 at 12:44:35 PM | View range-top
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
See my reply in the previous post.
view range top clip plane
Sat, Jan 24, 2009 at 7:56:31 AM
view range
Fri, Sep 7, 2007 at 2:28:04 AM
top primary range
Wed, Jul 7, 2010 at 11:15:12 AM
View range problem
Wed, Nov 5, 2014 at 10:18:37 AM
View Range
Mon, May 17, 2010 at 4:48:55 PM
Page generation time: 2.0334
