Forums >> Revit Building >> Technical Support >> MEP AutoCAD Export issues
Fri, Mar 11, 2016 at 5:29:49 AM | MEP AutoCAD Export issues
jamesm2505
I have created a pipe system within an existing architectural model, and when I export the sheets to AutoCAD a significant proportion of the pipework lines disappear (almost as though other pipe elements have a background mask). Is this an issue with my export set up / is there a solution?
Revit 2016 (modified architectural template) to AutoCAD 2013 (DWG)
Sun, Mar 13, 2016 at 12:46:02 PM | MEP AutoCAD Export issues
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Change the view to 'wireframe' before exporting ?
Exporting from Revit 2013 to Autocad MEP 2010 while retaining intelligent object
Sat, Dec 7, 2013 at 12:08:38 AM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Autocad MEP imported into Revit MEP Pros/Cons
Fri, Jul 22, 2011 at 1:08:45 AM
Architect using Revit while MEP use AutoCAD in the same office
Thu, Mar 19, 2015 at 1:53:05 PM
Revit MEP Differences
Wed, Jun 12, 2013 at 8:25:19 AM
Page generation time: 1.1888
