12 Users Online (10 Members):
Forums >> Revit Building >> Tips & Tricks >> Canadian Model Energy Code Analysis with Revit 2015
148 Posts No Rating |
Greetings.
Has anyone looked at using Revit to address the requirements for the new Canadian Model Energy Code? I am being asked many questions and hoping to connect with users who are working on this topic.
The Perscriptive method looks at percent glazing and R-values in the walls.
I was hoping that the Energy Analysis menues would give me some help here but I found none.
Has anyone gone here? Has anyone found a reasonable workflow ... beyond the old fashioned methods of surface area take-offs?
It's a big topic up here ... hoping for some collaboration.
thanksIan
Ian Shafer
Principal Consultant
True North S&F Consultants |
buildings in australia are subject to a star energy rating system.
a new industry has popped up in energy assessing. you need to be accredited (do a short course) and then you can assess buildings using the accredited softwares.
usually a program called first rate 5 is used,
another is Accu-rate
and yet another BERS Professional.
dwellings need to comply with a minimum of 6 energy stars and commercial buildings 5 stars.
these programs take into account climate zones, building orientation, glazing, insulation, thermal mass etc.
all good fun but time consuming, hence the rise of accredited energy assessors specialising in this field.
see attached link:- http://www.nathers.gov.au/
these programs may be adaptable to your region.
Strange energy analysis results. |
Sat, May 20, 2017 at 4:47:16 AM
energy analysis is great, but customize the windows? grrrr |
Thu, Mar 1, 2012 at 4:44:02 PM
GENERATE ENERGY ANALYSIS |
Sat, Nov 11, 2017 at 6:51:18 AM
REVIT 2014 Energy Analysis Tutorial |
Tue, May 14, 2013 at 12:44:40 PM
Revit 2014 Energy Analysis issue |
Tue, May 7, 2013 at 1:28:12 PM
