Forums >> General Discussion >> Revit Project Management >> Details not Referencing Backwards
Mon, Mar 7, 2016 at 6:20:49 PM | Details not Referencing Backwards
tws2189
When I place a "view reference" in a detail, the referenced view does not obtain "reference sheet" and "referencing details" in its properties. Callouts, sections, etc., seem to work fine from what I've found.  When those views are referenced in another view, the "reference sheet" and "referencing details" properties are filled in. However if only a "view reference" is placed those properties remain empty.  Has anyone found a workaround for this or have some suggestion on if I'm doing something wrong?
See attached image for clarification
Tue, Mar 8, 2016 at 7:12:40 AM | Details not Referencing Backwards
There is no problem here with Revit, this is a process issue.  When placing a view reference, you are given a pulldown to select the correct view.   Only a view that is placed on a sheet will have that data, not a view that is not placed.
Tue, Mar 8, 2016 at 10:02:57 AM | Details not Referencing Backwards
tws2189
Thanks for your response, We are having the issue with views that are placed on sheets.  See attached images for more reference.
Tue, Mar 8, 2016 at 2:24:02 PM | Details not Referencing Backwards
What is it that you are showing us?   I don't have a clue...is it a View title?  We were talking about View Reference.
A view title that is set up to back reference will only reference one location - the original location.  If that view is never placed on a sheet, then there will be no reference.
Tue, Mar 8, 2016 at 4:47:40 PM | Details not Referencing Backwards
tws2189
Sorry for the confusion. Yes it is a View Title that is set up to back reference.  The images were showing that the view is placed on a sheet, and that the view is being referenced through a view reference in another detail, but the back reference is not being updated.
Re-referencing details
Mon, Mar 30, 2009 at 12:45:15 PM
Finding Unreferenced Details Already on Sheets
Sun, May 13, 2018 at 5:10:42 AM
MODEL TEXT BACKWARDS [ 1 2 ]
Tue, Jul 29, 2014 at 3:51:36 PM
17
Typical Details
Mon, Mar 26, 2012 at 4:55:56 PM
Is their a way to change the Viewport referencing?
Wed, Sep 21, 2016 at 3:16:25 PM
Page generation time: 5.6049
