Forums >> General Discussion >> Revit Project Management >> Project won't close
Mon, Mar 7, 2016 at 10:36:46 AM | Project won't close
blf89f
I have been having an issue where the project I am working on just won't close. I close all associated windows/views and the project remains open some how. I know this because the project browser is still loaded with that projects views/sheets. There are also NO hidden views of any kind. I can actually open a new Revit issuance, open a project and when the open view comes up, if I close it (knowing there is only 1 view open) the same thing occurs.
Is there some silly setting that is causing this? Any help is appreciated!
Mon, Mar 7, 2016 at 10:59:21 AM | Project won't close
Have you tried picking the Revit R and then close?
Mon, Mar 7, 2016 at 11:19:46 AM | Project won't close
blf89f
Yes I have. It is greyed out as if the project is closed - see attached.
Mon, Mar 7, 2016 at 12:20:32 PM | Project won't close
Depending on your system, the Revit year you are using and how you work, Revit sometimes needs time to close.   It is not always immediate because it has to update its files.  The biggest contributer to this problem is having tiled windows.  Another slow down is 3D view with a lot of entourage or planting.  Revit has to update and save the contents of every active window.   Try to always save from a simple window like a  notebox but first use the close hidden windows option from the windows menu.Another problem is not properly closing a command.   I'm not sure if this is still a problem but it used to be.   Revit may be still waiting for you to finsh a squence.
Mon, Mar 7, 2016 at 12:49:47 PM | Project won't close
One of these problems in previous release.
Beams won't intersect or close-up to Structural Columns. Solution ?
Tue, Oct 18, 2016 at 2:01:11 PM
'Door' Won't Load into Project
Tue, Sep 28, 2010 at 7:11:37 PM
Project Browser Won't Dock Vertically
Thu, Oct 4, 2018 at 7:56:05 PM
3D View orientation won't lock
Sun, Feb 26, 2012 at 7:44:07 PM
Load Into Project.... AND CLOSE!
Wed, Jan 27, 2010 at 12:06:43 PM
Page generation time: 2.6810
