13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Staircase not going to levels?
Hi I am using Revit LT 2016. I am trying to put a staircase in my building but when I add the landing it doesnt sit at the right level.I drew a staircase outside of the building to show you what I mean and have attached a screen shot. Has anyone found this issue and know how to correct it?
Its only out by a couple of mm but its making this project really difficult
Revit is only doing what you tell it to do. If you create the stairs and tell it equal risers (as you should), then the landing height will be set by that. If you must hit a unique landing, then your risers may not be equal and you will ahve to do that in two seperate stairs.
Thanks WWHub,Your right that does work better, thankyou for that!
Staircase |
Fri, May 26, 2006 at 12:16:48 PM
Staircase help - winder staircase |
Wed, Nov 28, 2007 at 4:31:48 PM
Openings in staircase |
Sun, May 26, 2013 at 11:21:10 AM
staircase |
Sun, Oct 21, 2012 at 7:23:52 AM
New Stair Tag Family! |
Tue, Nov 11, 2014 at 1:48:59 AM
