Forums >> Revit Building >> Technical Support >> Creating Ribs Using Divided Surface Isn't Working
Sat, Mar 5, 2016 at 4:24:22 PM | Creating Ribs Using Divided Surface Isn't Working
YahyaMohammed
I'm trying to create intersecting ribs in a semi-spherical shape that has multiple curves. The mass itself was a success , the ribs i made of adaptive components , but instead of repeating them per spacing , i repeated them along the entire structure (see the pictures). Now the problem is that the ribs do not intersect perpendecularly to the ribs from the other direction (see the picture). Is there anyway i can make them perfectly intersect ? Moreover, is there a better workaround to create the mesh ?? thanks alot.
144367_1.JPG144367_2.JPG144367_3.JPG144367_4.JPG144367_Ribs_Adaptive_Component_Just_For_Reference.JPG
Sun, Mar 6, 2016 at 1:10:00 PM | Creating Ribs Using Divided Surface Isn't Working
YahyaMohammed
It Turns Out I had To Check The Orientation of the Adaptive Components , I Created Two Different Adaptive Components , One For Each Direction; So Basically The Same Family But One Of them Is Right-angle Rotated.
Sun, Mar 6, 2016 at 1:12:03 PM | Creating Ribs Using Divided Surface Isn't Working
YahyaMohammed
It Turns Out I Had To Check The Orientation Of The Component. Plus, I Created Two Families Of The Same Family And Rotated One Of Them For The Other Direction.
In-Place Mass Family with divided surfaces can have seperate worksets?
Tue, Feb 2, 2016 at 7:18:26 PM
Question about modify divided surface
Tue, Mar 30, 2010 at 7:03:39 AM
Adding Material to Divided Surface
Thu, Apr 17, 2014 at 10:40:12 AM
Parametric Curtain wall panel in divided surface
Sun, Jan 31, 2010 at 8:08:54 AM
Adaptive Family - points based
Thu, Feb 23, 2017 at 3:19:09 AM
Page generation time: 3.2135
